96_S14_SE »
https://forums.nicoclub.com/96-s14-se-u2649.html
Mon Jun 23, 2003 9:26 am
Tell your mechanic to blow that 100k mile **** up someone elses ***!!! No seriously do it.... do it now. Ive beat the living hell out of my KA and automatic transmission since I got her in 99 with 28k miles on her. I now have 116k a 1" thick stack of time slips, 10 or 11 autocrosses, and I drive her hard on the street as well. I cant get a set of tires to last more then 20k miles and thats with proper rotation, maintenance, and 0 burnouts...
Oh yeah she runs and shifts (remember the auto part) perfectly, btw. But then again I take 100% care of the car mechanically.
Anyway everything went out eh??? If you are sure its not the battery / alternator (a simple jump start that results in nothing working still while connected to another car / box / machine, would rule these out), I would then check for main fuses being blown...
One thing Ill suggest looking at as it sounds immediately sudden without warning, is the 30amp ignition fusable link. Check to see if that is blown. If it is (fuseables dont always blow visible...), locate the valve cover breather tube. Look at the harness running under it (comming from the injectors), and check underneath it. Theres a design flaw on the 95-96 where that harness will rest on a bolt on the head and eventually eat through it, nailing r/bk or the primary ignition wire shorting it and killing the car instantly (to leave you stranded wondering wtf is up with the ignition and a slew of other ****.... ive been there and spent the rest of the next day finding this lil short as the last thing I checked hehe)....
Check this out as it sounds about right to me.... If not, well fix it anyway as it may happen eventually. To fix, youll need to wrap the wire with electrical tape (where it was worn, skip this if for precautionary measures of course) then take a 5/8" heater hose 3" or so long and slice it in the middle. Wrap this around the fixed harness section and wrap with tape again. I used silicone tubing I had on hand then later found out this is a listed problem and thats exactly how the techs fix it...
