what is your budget? Low budget get an S13 (89-94) High budget and you want something nicer? Get an S14 (95-98) As far as what you should do? Make sure you get a quality rear differential. Unless you are on a tight budget, then u can always weld the diff but i dont recommend that... Also a good set of coilovers and RUCAS (Rear upper control arms) those will help you dial in your rear camber for the track. Are you planning to daily drive this drift car? or is it track only? If track only then delete all unnecessary interior panels/seats/AC stuff under dash/etc and put a roll cage in it. Depending on the motor you have the KA has great torque and is fun to slide around with.. the SR20DET is a great motor with a turbo that makes drifting almost effortless. You can always add a turbo to the KA motor but if not done right and you cut corners, it will inevitably blow up. hope this helps..Dylannf wrote:Hey everyone im dylan and im really new to 240sx
i am looking to buy a 240sx and i want to build it into a drift car. What 240sx do you think i should buy and what should i do to it to make a drift car.
there are so many answers to that.. it varies significantly.. if u found an S14 shell or something for a good price build that, hell.. you never told me a budget.. do you know absolutely nothing of what you want? have you done ANY research?Dylannf wrote:how would a s13 be cheaper then a s14 build?
get ur suspension and drivetrain in check first man. coilovers and adjustable EVERYTHING also get a differential for the rear. there are many OEM LSD's that should bolt right into the rear with the swap of the axels too usually. as stated before, the ka has enough torque to get the car sliding but has a hard time doing any really smokey stuff. if you can.. find a car for like 1500-2k buy coilovers and a decent set of wheels/tires. nothing crazy tho to keep the tire cost down when u shred thru ur sets. gut the f*** out with the exception of the two front seats, dash, etc. get a cage put in it. see how u like it an mod it accordingly to suit your tastes.. if you've come THAT far and done some trial an error an talked to some people at events then you should know by then what to do next... goodluck, manDylannf wrote:have done some research and im still stuck between the body styles and i was thinking a budget and 7 or 8 grand i no i wanted to stiffen up the body and work on the suspension first then i wanted to do work on engine and stuff like that but in the nissan world in completely new to it
alms24sebring wrote:
Also ridiculous wobble, your sig is a little too big.
