New tires
sbird1
Car: 2006 BMW 325i
Ok, guys. It's time for some new tires and I need some direction. Right now I'm running a set of 215/40/R17's. They look like this:I want to go with a larger sidewall as I have a lot of empty space and think a larger tire would look better as well as ride better and last longer. I've searched here (NICO) and here (http://www.miata.net/garage/tirecalc.html) and I'm unsure how high to go. I don't know if I should go with 45's 50's or 55's. Some advice or suggestions would be much appreciated. Thanks!
Vidra
215/45/17.... i run that
NiSmo240luvR
dont put anything bigger than a 45 on a 17. id say stick with a 40 and just drop it to get rid of the gap.
sbird1
Car: 2006 BMW 325i
I think I'm going to go with some Falken ZE-512's. They're 215/45/r17. Cheap, too!
whiterps13
Car: white LE hatch
Wheels and Tires forum next time, please.zeroforum/140Run a 215/45/17 though..
wankelTII
Just go to a 225/40/17 Tire is wider and side wall will be taller, kills 2 birds with one stone.Go with a decient brand of tire and a v or z ratingI have had good luck with Nitto NT450 ZR's for long life, a great hold, and they are quiet if you do break them loose.Kumho tires are good too. The Escta 7-11 dosent last as long but is cheapSome of the Yokohamas are also good and cheap
whiterps13
Car: white LE hatch
No man, 225/40's will not be a good idea.
Im guessing those wheels are 17x7 +40 ish. If you go to a 225 width, they wont clear coilovers up front. Trust me, stick with the 215 width.
sbird1
Car: 2006 BMW 325i
Sorry about the wrong forum thing. I appreciate all of the info and opinions, guys, and I think I've made my decision on the tires. Yay for NICO!
wankelTII
double post - days later, i know sorry
whiterps13
Car: white LE hatch
wankelTII wrote:Just go to a 225/40/17 Tire is wider and side wall will be taller, kills 2 birds with one stone.Go with a decient brand of tire and a v or z ratingI have had good luck with Nitto NT450 ZR's for long life, a great hold, and they are quiet if you do break them loose.Kumho tires are good too. The Escta 7-11 dosent last as long but is cheapSome of the Yokohamas are also good and cheap
I dont mean to be a d!ck, but dont keep giving information that you have -no- clue about. Seriously, I already corrected you once. Why would you say the exact same thing again?
If the OP went out and got your suggested tire size, he would be stuck with wheels and tires that dont fit.. Dont give suggestions if you dont know what youre talking about.
