You might also consider the Avon M500 (if it is available in the right size.) It is perhaps better than the Avon M550. I think that maxnix has posted over in Infiniti General that he likes the M500 - albeit on an Acura Legend, as I recall.johnsha wrote:I am looking at Avon M550 AS and Kuhmo ASX (both highly rated on TireRack.com) in the 235/50/17 for my '03 Sedan. Is anyone out there running either of these tires.
That will depend a lot of how the tire manufacturer measures them, of course! You cannot compare tires between vendors, of course.johnsha wrote:I will need to do the Avon M550 over the M500. I drive very aggresive and I'll wear though a tire with less than 300 rating in about 5k miles.
Hmmm, a tough call. The normal recommended minimum for a 245/45-17 is 7.5" rim width (a few manufacturers want 8.0") - no reputable vendor will make a guarantee for any less due to liability concerns.johnsha wrote:My Sedan has 17x7 wheels with a 45mm offset.Do you think the 245/45/17 will work?You are not kidding the is a much better selection in that size.
They are pretty quiet. I'm not going to say they are the quietest tire out there, but they keep the road noise down to an acceptable level in my opinion.Duggins1 wrote:Thanks for the input. This is the info I need. Are these tires quieter and smoother than the Goodyear Eagle's. I'm looking for a QUIET tire and teh Yokohama has had the best noise/comfort rating. We'll be making 11 hr. one way trips and the road noise gets old.
Thanks,Duggins1
I wouldn't suggest the 245/45 wheel. Get the 235/50/17, its almost identical to oem tire specs. You will get a .5 wide contact patch and will fill out those fenders just abit. I would reconsider the AVONS as well, I believe they weight 31lbs, compared to the 26lbs stockers. I will probably go with the Kumho ecsta ASX's. 420 AA A, high performance all season.johnsha wrote:I will need to do the Avon M550 over the M500. I drive very aggresive and I'll wear though a tire with less than 300 rating in about 5k miles.
John Sha'03 G35 Sedan'00 Saab 9-5 Aero'01 Dodge Grand Caravan ES
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
