New tires load/speed rating question
A home for 1983–1989 300ZX owners!
YowzaZ31
Car: 86 N/A
Looking to buy set of 4 BF Goodrich Radial T/A’s and found a really good deal for my ’86 N/A. I don't drive it much, put less than 2k miles on it per year. The tires that are on sale have a load/speed rating of 93/S (up to 112 mph). My '86 owner’s manual calls for the tires’ load/speed rating to be 90/H (up to 130 mph).
Will I have an trouble with the these new tires if I run with them?
YowzaZ31
Car: 86 N/A
My second question would be ..... is there another size tire other than the 215/60R 15 that I can safely run with??
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
The S rated tires are fine as long as you don't plan to do sustained driving north of 112 mph. 205/50 R15 is a more common size. On the stock 15 x 6.5 wheels you can run anything from a 195 to a 225 width without issue and 45-60 % aspect ratio. If you up size the wheels you'll find more tire options but as the size goes up so does the price.
YowzaZ31
Car: 86 N/A
evildky:
So any of these sizes will work??? Any more not listed?
Tire alternative chart has:
195/65R 15 @ -0.8%
205/65R 15 @ +1.2%
225/60R 15 @ +1.6%
evildky
06 Nissan 350Z GT
I'd personally go for a 225 50 15, very common size, it'll lover the car a bit, increase contact patch and reduce the sidewall and get rid of the bg sidewall flex.
YowzaZ31
Car: 86 N/A
225 50 15 on the stock 15 x 6.5 wheels???
evildky
06 Nissan 350Z GT
I meant to say 205 50 15, but the 225's would work too just might crown the tread a bit
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
Actually I have run 225/50 15's for about 20 years now and they work great. I have had others say that it would be too wide on the rim but they fit just fine and work just fine. I have a set of Bridgestone SO3's on there right now that are finally coming off in favor of new 16x8 Enkei Comp wheels with 225/50 16 tires.
There are a few choices left in the 225 size on the HR speed rating but none in ZR or above unless you want autocross tires.
Return to “300ZX (Z31) Forum”
