New tires for the Q!!!
dougs98Q45
Car: Golf
Howdy all- Had Discount put a new set of rubber on the Q last night and curious if anyone has any experience w/ them.
Put on Yokohama YK420's in 245/50/R16 96V. Looked em up last night and they're not on Yokohama's or TireRack's websites but I suspect they are nearly identical to the Avid T4. (awaiting email response from Yok.)
Boy the wider rubber sure looks nice! In limited driving so far the ride is not much different (was a little more drifty but could be just that they're new) and that's a releif cuz I was worried I'd lose that smooth ride. Of course, time will tell...
Anyone had these before?
szh
Car: 2018 Tesla Model 3.
People have had bad experience with them, unfortunately. Check out the following thread:
http://www.nissaninfiniticlub....YK420
If I remember correctly, AZhitman had serious enough problems with them (from Discount Tire) that he got them to swap for Falken Ziex's on his Q.
Z
dougs98Q45
Car: Golf
Yikes! I spaced on this one (Duh!) but will seriously look into!Thanks for the reminder Z!
SmithSR
Car: 240sx
Still no official word (that I have seen) about recall. Looks like the tire is being swept under the carpet, so to speak.
I noticed you said "Looked em up last night and they're not on Yokohama's or TireRack's websites"
This could be due to the fact that there is an internal recognition of a problem with these tires, and it's being quietly handled. aka: phased out of the lineup..
What other models/brands did the Discount guy pitch you??
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
They are a Discount only tire. Check the thread where one blew out in Montana at speed.
Cheap tires are just that.
SmithSR
Car: 240sx
Just for kicks, check the build date in the DOT stamping.
if they are a Discount-only tire, this means special bulk order from Yokohama at a steep discount just to get them moved. They built too many and demand was never what they had aniticipated.
The tires have been sitting in a warehouse for over a year, I would wager.
95% of tires we install daily have build dates from '03. Usually mid-to-late '03. The remaining 5% are "special purchase" tires that were wholesaled to us at a deep discount.
There's good profit margin in selling bulk order models/brands, but for a Q45 driver, we(tire shops) aren't doing them justice by selling the cheaper tire. Hopefully, if you DO have trouble, then Discount will man up and treat you fairly with a credit, and a different tire selection.
dougs98Q45
Car: Golf
Thx Guys!
Is the date stamp on the outer sidewall & if so how coded? Would V 042inside the bar-code like depression be it? Thinks I'll Stop by on the way home.....
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Also, most tire stores don't inflate the tires as much as I like them, when putting them on.
I run mine areound 40 PSI.
The tire place only had 32 PSI in them, when I got home. The drive is very squishy, with low pressure.
Definitely read AZhitman's thread.
dougs98Q45
Car: Golf
Just got off the phone w/ the discount guy- he was really cool about it. The car is getting parked for a few days (like 20 miles on the new rubber) while he orders me a set of Pirelli P7000's which will then be swapped out straight up. Thanks for the reminders guys. I had actually read all these posts before and I guess it was a case off over saturation w/ all the info I'd found. I've been trying to make up my mind on a set of tires for quite awhile. Now I know how Homer feels when he goes 'Doooohhhh!!!'
PalmerWMD
Car: 2004 350Z
Sounds like they did the right thing.
Fred...:)
Q45tech
We have had a few customers who ran this tire in this size.Since it is a 51 psi max tire and [single ply sidewall [for US]] you may find that 40 psi inflation is required on the front and rear to get satisfactory handling.
320 A A 96W
szh
Here is a link to an older thread where I posted information on good tires for a Q45 - take a look at my long post on the second page:
http://www.nissaninfiniticlub....ber=2
Z
szh
Doug,
Since you mentioned 16" rims before, I assume you are getting the Pirelli P7000 in a 245/50ZR16 size. This is $104 at TireRack, by the way.
I do not mean to second-guess your decision too much, but, IMO, for a bit more money ($125), the Firestone Firehawk SZ50EP in 255/50ZR16 is a way better tire. It is much stronger (1687lbs vs 1565lbs load rating) and a slightly better diameter (26.1" vs 25.7") compared to stock sizes, thus giving you less speedo error. Admittedly more expensive ...
By the way, SZ50EP is 340 AA A 99. Dennis gave the specs for the Pirelli.
Z
dougs98Q45
Car: Golf
I appreciate all inputs! Pirellis are going on tomm. I was under the impression that Discount didn't sell the Falkens. Now it appears they do, they just don't stock them? I would have paid the extra no problemo but this guy has been really nice and put up with enough of my dithering so the Pirellis it is. Not his fault. I can deal with an under 2% speedo error (esp. if I know about it!) I just want a decent tire that will last a reasonable amount of time. Will definately look into the Falkens next time in whatever incarnation they are then. 40PSI eh? I must admit, I'm curious to see how they turn out....
Edit- said Falkens but meant Firestones. Both were tires I had interest in but beleived that Discount didn't stock.
YK420 is a "store brand" built specifically for Discount by Yoko.
Not a 320 treadwear as Dennis stated but a 420 rather.
Discount carries the Falkens as well, and aside from the fact that mine were FREE, their prices on the Falken Ziex-512 are competitive. If you decide to do these, consider the 255/50/16 as they are identical to stock diameter and have a 99W rating, and look spectacular.
Also, never pay the first quote at Discount - They have some "haggling" room. :)
dougs98Q45
Car: Golf
Right then- revision #2: there was a snag ordering the Pirellis so I took that opportunity to see iff AZ's reccommended Falkens in 255/50/16 are available. They are (mid-next week).
AZ- you run the second gen 16's right?? So I think I'm okay w/ rim fit, just wondering about wheel well clearances. Know any second gen cars running this size? This is kinda sudden and I'm stuck at work so I can't tear into it yet.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
My wife runs 245/50-16 SZ50 EP on her 2K FY33 and loves them. I do too. Shouldn't have any troubles with the 255 size.__________________Brian1995 Q45 & Q45t & 2000 Q45
Discover the power of the button!
szh
Hi, Doug.
I put the Falken Ziex's on my 1995 Q (in a different size ... 245/45-17) and they seemed very good! Not quite as nice as the Firehawk SZ50EP for handling and quietness, but they were certainly much less expensive, so the trade-off was easy to make (particularly since the Firehawk was not available in that size, either!)
I cannot comment on the fit on the second-gen Q, but I would guess that if your wheel offset is in the 35 to 40mm range, it should work just fine. FWIW, the Firestone might be a better fit in the wheel well, since it has a narrower tread-width and a bit more of a "curved" section shape.
Z
dougs98Q45
Car: Golf
Cool! I'm going w/ it then. (I know you've heard it before...)Next week can't get here soon enough!Hey- little kids get christmas.....
szh
dougs98Q45 wrote:Cool! I'm going w/ it then.
Good Stuff™! :)
Z
You'll be fine.
Can't wait to see them!
p.s. I'm pleased with the traction, noise and ESPECIALLY the wet-weather grip. Takes some intentional throttle application to spin 'em in the wet, and lateral stability is solid.
dougs98Q45
Car: Golf
Great news! Thanks all!
Q451990
dougs98Q45 wrote:255/50/16 are available...So I think I'm okay w/ rim fit, just wondering about wheel well clearances.
I think you'll be fine - I'm running your wheels (standard 97-00) and that size in the Michelin XGTH4. They fit fine, and the car handles very nicely with that size tire.
It appears that the 15" 1990-1996 tire fitment and the 16" later wheels were still designed for the same overall tire diameter and width, if I remember correctly.
Heath
zinkie13
Car: 1992 Lexus SC300 Single Turbo
I have Fulda Extremo 245/50/16's on my Q. I would recommend them highly. However they are pretty expensive. The tires are Z rated for speed and the load rating is a 98, 4 points higher than what the car requires for driving. I was able to test some high end yoko's, pirellis, and continentals. Another good thing about the Extremos, they are the only directional tire I have driven on that can actually grip in snowy weather.
eQlipse
Car: 2006 Infiniti M35X
I have the Falkens & have enjoyed them thus far. I'm running 'em 235/55/16 matching OEM diameter. They look pretty nice & handle pretty well in rain & snow. They are a bit harder to spin in the wet like AZHITMAN stated. I'd recommend them.
dougs98Q45
Car: Golf
They're on! Just had the 255/50/16 Falkens put on tonight. All okay so far and I will update after some miles are on 'em. In 20 miles I can already say that the have less 'lane drift' on the freeways than the Yokos but that could be misleading as they're so new. They are quieter also. That my melon head can tell this in 20 miles on each set makes me feel pretty good about my decision. Thanks once again to all of you good folks that chimed in. Probably saved me from a future headache! Also, kudos to Discount for putting up w/ my you know what and being nice about it to boot. I'll be writing a thank you letter! And while I know it's FAR from the most important thing about tires, DANG they look nice!
Toldjaso!
Love my Falkens - Best-kept secret in tires, IMO.
