Footprint is primarily a function of PSI inflation and weight on tire. +-1 size makes little difference in braking. A higher load index [carrying capacity] will improve braking just as it does handling.
TorontoAndy wrote:Are you saying that a 255 tire will have worse stopping than a 245 or that I should just look at the braking review data and choose the best wet stopping tire I can get??
my 'undergraduate' understandinf of what he meant.....is the the slightly larger footprint doesn't matter as much as the load index. I do believe that the 255/45/18 has a higher load rating than the 245/45/18.
Also, from personal experience, the 05 has a 'higher rear end ratio' ....goes faster off the line and runs at a higher RPM at a steady speed than the 02. If?when I replace my 02 w an 05 or 06 I personally will absolutely run the 255 on the stock rim. That will lower the rpm at highway speeds just a little but will also improve gas mileage
