tramp_drift240 »
https://forums.nicoclub.com/tramp-drift240-u50915.html
Sat Feb 16, 2008 7:03 pm
so you have full replacement fiberglass fenders on the front?
if so, bummer. i dont really know what you should do about that other than raise it.
which i definitely dont want you to do.
EDIT: if youve got coilovers, you should try to find some higher spring rates to replace your current ones, itll keep the front from bouncing enough to rub against it. ive got 10 kg/mm in the front and 8kg/mm in the rear, i dont have to worry about any rubbing, even when i get some better wheels.
