stiergott »
https://forums.nicoclub.com/stiergott-u17357.html
Sun Nov 27, 2005 8:47 pm
so heres where i am now. the car will start everytime, it has a slight random miss, there are no boost leaks, the TPS is good, the IACV is good(i can turn the screw and change the rpms), and it wont rev past 2500rpm. i know what your thinking, MAFS. well i have swapped MAFS and there is no change, and i have put the mafs on another car and they work fine. which leads me to believe the wiring is bad and or its not grounding correctly. the timing might be off a little too but that has nothing to do with the 2500rpm cut out, i mean it will not rev past 2500rpm. tomorrow im going to set the timing and im going to ground the mafs to the body. what ever is going on is electrical and has to do the mafs, if anyone can think of anything else i have missed please let me know.
