So my TPS has been acting up lately. Its been happening since I bought the truck about a year and a half ago. The issue was only intermittent...it had my local shop quite lost. After a long drive the revs would bounce between 1,500 and 2,500. Sometimes they would even hold around 2,000 Rpm. If I floored and and let off a few times it would eventually come back down to regualar idle. One night it did the Idle bounce in my driveway. I remembered an old trick to finding sensors that were bad. I tapped the TPS with the handle of a screwdriver a few times and voila! Idle dropped down immediately. I have also been experiencing harsh 1-2 shifts. I know that the TPS controls alot of the drivetrain components. It didnt act up all winter/since i tapped it with the screwdriver but last week it started doing it again. Then again, only after long periods of driving. My scenario is that the TPS is in a position for a long period of time(highway or steady speed) and sticks. The rev bouncing is caused by the TPS holding the throttle open but the computer sensing something else. I am most likely wrong, but that just the way i think it is. Also, NO check engine light. No pending codes either.
Now that you heard me tell my story...I finally ordered a Sensor online last night. Should be here sometime next week. I am wondering if this is a direct swap or will it need to be setup/calibrated for my truck? I would be really happy if i didn't have to go to my Nissan dealerhship...although, I probably should get that recall taken care of.
Thanks alot!
