New thought on 240sx clusters....
NICO's official source for Nissan upholstery, carpet, headliners, and trim information!
thang nguyen
Car: 1989 Nissan 240SX Fastback
Has anyone out there try to update the look of the clusters on their 240sx???? I have an S13 with HUD and the speedometer and other lights within it is very very dim and ugly lookin....The physical shape is perfect otherwise. I was wondering if anyone has tried replaceing the bulbs wth LEDs or anyother way to brighten up the dash other then the EBAY white face that glows at night. I was lookin to obtain a black face with red mubering and dashes at night...if anyone out there has tryied or have ideas...let us all know. thanks.
DALAZ_68
Car: 90' 240sx CA18det
my friend u need thishttp://www.club240.com/forums/...40228
WhiteKnight
Car: Nissan 240SX
The white stickers are the easiest to do. I put in the indiglo and they don't light up.
Beems240sx
Car: built S14, E30, R6 raven
DALAZ_68 wrote:my friend u need thishttp://www.club240.com/forums/...40228
do you know if the LED bulbs are the same for an S14? i love how simple that was to do, i must have it
95240SE
Car: 95 240sx
led size is the same for s14 except you only need 3 of them.
elo240
Here ya go. This is my setup.
thang nguyen
That setup is pretty dope. Let me know what you used.
ANVIL
Car: RB25DET S13.5
damn that looks nice... with the digital climate control!
is it fully functional? about how much does it cost to get one fully functional?
MastaYu
Car: 92 Nissan 240SX SE HB
elo240 wrote:Here ya go. This is my setup.
nice I like it
elo240
Ok for the blue I used the WLED-x5 LED Wedge Base Bulbs and #74 LED bulbs from superbrightleds.com. For the needles I use importintelligence.com IntelliGlow Needle Kits. I also scaped the white piant off the back of the needles with a razor blade and then repainted them red with a testors paint pen. The climate controls are a little more work as there is no direct fit leds. I used the same #74's, trimed the base off and soldered them into place.
Add yes the DCC are fully functional and you can find complete setups on ebay for around 250. There are several write ups here on nico on how to install them. Its not to hrad to do just read the threads throughly.
AZ89two4Tsx
Not completely about the cluster but it could give you some ideas later on if you decide to mount other gauges.
zerothread?id=328156
Btw, elo, do you have a day shot? I didn't know you colored the needles. I'm curious to see how it looks.
elo240
Here ya go one daytime pic
MACAuto
Car: '89 240SR Track Car
All very nice with the lights and all, but on the S13 cluster, you really should consider junking the HUD or the 115MPH cluster and get a JDM cluster which can be recalibrated to accurately give you 0-180MPH, and miles on the odo. You will need a resistor, and a small hole drilled in the cluster case for access to the pot for calibration. A chassis dyno can give you the safety of not losing control while calibrating. This will work on any twin cam s13 or any s13 with an SR20DET swap. Also works with either the KA or SR speed sensor (different resistor value). PM for details.
MACAutoParker, CO
elo240
Thanx but no thanx. I like the my HUD.
orangeNblue
Car: 2008 Nissan 350z
So i'm thinking about doing this to my car....from what I've found though it looks like superbrightleds.com makes some led's that would fit straight into the climate control lights as direct replacements...
the NeoWedge series LED Lamphttp://superbrightleds.com/instrument.html
the 3mm NEO3 looks exactly like the ones I took out of my 1998 240...I'm going to try these and the WLED-x5 Wedge Base for my gauge cluster this week along with the needle kit
elo240
Those LEDS look nice. They didn't have those when I did mine.
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
My girlfriend bought some "jdm" pink bulbs off another S-chassis forum and put them in.
BEFORE
AFTER (gotta get a better pic)
orangeNblue
The neo 3mm from superbrightleds.com didn't quite fit but with a light push they went in just fine and work great...they look stock just more white and a lot brighter....
H8tred
Elo, where did you get the red needles?
AZ89two4Tsx
^ He colored them as said in posts above.
The backlighting however, came from http://www.importintelligence.com
H8tred
Yeah, even I breeze through the posts sometimes. Completely missed it. I'm debating leaving it white, or doing something similar. Really don't want to pull the needles, I've heard horror stories. As far as the import intelligence lighting, I'm just heat shrinking LEDs to the diffusers. I'll post up pics when I'm done.
playero_loko
Car: 1991 240sx
MACAuto wrote:A chassis dyno can give you the safety of not losing control while calibrating. This will work on any twin cam s13 or any s13 with an SR20DET swap. Also works with either the KA or SR speed sensor (different resistor value). PM for details.
i'd like to know how!!! also does anybody know if a bezel is made for the digital cluster? i think a bezel would be more appealing while only changing the led bulbs... does anybody know???
Scuffed_ChukiCoupe
Car: Ka-t coupe
any1 know where the #74 led bulbs go on the cluster? like what part does it exactly illuminated. i just bought the 194's and id kinda like more.
tonis56
Car: 04 Titan Crewcab
I know what im doing tomorrow!
PancerzSX
Car: 1995 240sx SE SOLD
1992 240sx SE on Stance SOLD
I think that is the first mod I am doing to my s13 when I pick it up
Return to “Interiors”
