New Member First 240SX!
dongpane
Hi, My name is Stan. I was into 240sx for a long time and after all these years I finally got myself a 240sx Hatchback. Thinking about swapping the engine to a SR20DET. It's a 1990 240sx with 130k miles on chassis and engine which is a KA24E. All stock no mods. Bought it for 1.9k. Without the RIMS.
Problems / Missing
-Driver seat is broken doesn't stay still.
-Head Gasket needs to be replaced
-Missing Stereo
Other than these problems the car is in a good condition have a look at the pictures. Advices would be very thankful.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
looks pretty clean. good luck with the car.
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
Very clean car. You might want to think twice about a SR20DET swap in a 240 in Califa.... Good luck.
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
Welcome! Nice find .... Good luck with it whatever engine you choose, and have fun! :dblthumb:
Speckid4
Car: 1995 240sx
1993 240sx
The single cam isn't a bad motor, it all depends on your goals. I think the single cam also sounds very good with the right exhaust. Work on fixing everything thats wrong and getting the car running smooth before going crazy with mods, after all the car is 20 years old. Don't forget to lower it :bigthumb: needs lowering. Sounds like you need new seat rails. You might be able to find some here on nicoclub in the marketplace section under interior or complete part-outs. Do your research, and try your best to do things right. There are a lot of experienced people on the forum that will be glad to help.
This is your best way to get simple questions answered:
the-i-m-new-here-and-i-have-a-simple-qu ... 13343.html
Happy Modding!
Jimmy :dblthumb:
dongpane
Lobo240sx wrote:Very clean car. You might want to think twice about a SR20DET swap in a 240 in Califa.... Good luck.
why do you think sr20det is not a good choice to swap in california? any specific answer to it?
dongpane
thanks alot guys for your advices. Seems like the head gasket isn't going to be a big problem?? lol not quite sure if it isn't any advice on that?
numbnuts240
2011 Ford Focus
2010 Mazda 3
it's illegal. won't pass visual inspection or smog. unless you pay someone off to pass the inspection on the low.
dongpane
it's illegal. won't pass visual inspection or smog. unless you pay someone off to pass the inspection on the low.[/quote]
oh god.... swap sr20det was the goal for my 240sx.... dang it... need to find a way around it... um. for the rims if the suspension is stock, what kind of rims are recommended? becuz i'm pretty sure i have to swap the suspension which i'm going with Tein SS. have no idea before i change the suspension what is a good rim that fits and look good on the 240. any idea??
AndrewMinervini
Car: 1993 nissan rps13
oh god.... swap sr20det was the goal for my 240sx.... dang it... need to find a way around it... um. for the rims if the suspension is stock, what kind of rims are recommended? becuz i'm pretty sure i have to swap the suspension which i'm going with Tein SS. have no idea before i change the suspension what is a good rim that fits and look good on the 240. any idea??[/quote]
Depends on what you wanna pay for em.
Lobo240sx
oh god.... swap sr20det was the goal for my 240sx.... dang it... need to find a way around it... um??
Engine is illegal, but it will pass fine if tuned correctly + A very good CAT. It's been done without one too. Barely passed!!
In Texas you can get away with 220 Hydro Carbons. I'm sure in California it is a lot lower to pass probably like 120 lol. Plus people in California that do inspections are very educated in the 240 SR swap department because of other jackasses street racing getting busted.
dongpane
Around maybe 6-700 is the price range i'm looking at.
Brandon1605
Car: 1989 Nissan 240sx (S13)
Head gasket is a relatively easy fix if you are mechanically inclined. The real question is what caused the headgasket to go in the first place. Usually a headgasket blowing is the result of some other issue that was ignored.
King Chilie
Car: 240sx, S13, 1993
Monte Carlo SS, 1985
Chevelle SS, 1968
Speckid4 wrote:The single cam isn't a bad motor, it all depends on your goals. I think the single cam also sounds very good with the right exhaust. Work on fixing everything thats wrong and getting the car running smooth before going crazy with mods, after all the car is 20 years old. Don't forget to lower it :bigthumb: needs lowering. Sounds like you need new seat rails. You might be able to find some here on nicoclub in the marketplace section under interior or complete part-outs. Do your research, and try your best to do things right. There are a lot of experienced people on the forum that will be glad to help.
Happy Modding!
Jimmy :dblthumb:
im in the same boat, fix whats wrong, then worry about mods, ESPECIALLY if its your only means of transportation! but if it isnt, a clean running car is better than a "project" collecting dust.
AndrewMinervini
Around maybe 6-700 is the price range i'm looking at.[/quote]
In that case xxr's are probably your best bet for new. you could most likely find something nicer and better quality used for that much i have the flat black with red strip xxrs just til i do 5 lug conversion. they dont look horrible now that the car is lowered
ash16847
Car: 1989 240sx hatchback
1991 240sx hatchback
very clean car, although IMO Im not likin the wing... I would probably just take the money you'd save from SR20 swap and build the KA24E a bit and turbo it. go KA-T. I dont see why you couldnt get around in cali with that. although im not sure on cali laws so...
dongpane
ash16847 wrote:very clean car, although IMO Im not likin the wing... I would probably just take the money you'd save from SR20 swap and build the KA24E a bit and turbo it. go KA-T. I dont see why you couldnt get around in cali with that. although im not sure on cali laws so...
I took out the wing. Well I made up my mind to put a SR20DET into the 240. Was thinking about putting the Turbo on the SOHC but... SR would be more worth it to me. So many maintenance to do on this car... Thanks for the reply tho.
krash
fixd'd your pics.
Looks clean man!
gigabit240
Car: 92 s13 hatch -sold
98 s14 kouki -current
Look for Razi's build thread. He has a nice stock looking ka-t setup.. If you're gonna go sr then you'd only be able to use it on the track.
dongpane
krash wrote:fixd'd your pics.
Looks clean man!
thanks alot! haha
AZ89two4Tsx
SRs can EASILY pass smog. No big worries there.
Visual inspection, however, is a different story. They don't do it here so it's not a concern but I would do some researching about your specific area.
dongpane
Hi guys...its been aong week... I sold the one i bought... And looking for a new 240sx.. I was looking for a manual but.. Came dOwn to this car.. http://losangeles.craigslist.org/lac/ct ... 43256.html Check out it out and please send me some advices.. The guys is asking 1100.. Thanks guys..
DanThaMan
Car: 1993 240sx
looks good! and its not super over priced, I would be weary of the overheating issue though. but for that price I would go for it if the shell is solid.
BTW is Dongpane you're real name? :poke: lol
dongpane
DanThaMan wrote:looks good! and its not super over priced, I would be weary of the overheating issue though. but for that price I would go for it if the shell is solid.
Thabks for the advice... I saw the car IRl but... Its not in a perfect condition... Its around 6/10? Its going to be my daily... So... And my real name isnt dongpane lol just user name haha
Chaluska
dongpane wrote: oh god.... swap sr20det was the goal for my 240sx.... dang it... need to find a way around it...
why an SR swap? keep the SOHC, and get a basic turbo kit for it, and you will smack the s*** out of sr's all day long, and have better driveability, with extreme ease of finding parts.
edit:
and be legal
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
Chaluska wrote: why an SR swap? keep the SOHC, and get a basic turbo kit for it, and you will smack the s*** out of sr's all day long, and have better driveability, with extreme ease of finding parts.
edit:
and be legal
first this is a stupid comment, two... a ka-t will not carb legal either. smog and vehicle modication regulations in CA are a PITA. please do research before you give someone wrong advice
SOUNDWAVE333
Car: '90 stock s13 hatch
HEY! THIS WAS MINE!!! HAAA!
I'm the guy who sold it to the guy who sold it to you!!! HA that's my driveway! With my kouki in the back!
Haaa I kind of miss her. :sad:
Wait I just read the thread. How much did you sell it for? To who? Someone who knows about 240's? or someone like the guy you bought it from.
