zero_gripS13 »
https://forums.nicoclub.com/zero-grips13-u21031.html
Tue Jul 07, 2009 6:31 pm
ok got my swap runnign which makes me extremely happy since i built it from ground up and its running lol she fired first turn but there a few bugs to work out and ive been searching for information but i figured a discussion and brain storming might help triger some useful advice/suggestions.
syptoms
high idle (1500-1800)stumple hesitation 2-3.5k (lack of responce and low end)
those r the main ones, now i know theres a vacuum leak i found a few with soupy water but i need to take out the propane and test for more im pulling 13-20 vac and 9psi boost.
high idle. now if i unplug aav (thing near fcid) the idle goes down to what its set at with the 10mm screw which is about 800 plug it in and it goes up. when its cold it idles about 1k then goes up.
timing is set to 15btdc at 800 rpm by unpluggin aav and then setting it.has brand new nissan coolant temp sensor, bosc o2 sensor. now i dismantled the aav and cleaned and everyhting when i put it on (im going to remove it and send power to it and see if its moving or not, but could it be just bad and causing my idle to remain high?)
now im runnign ka tb but ive check throttle cable tension and the idle stoper and neither at making it stay open
other issue is the stumble hesitation comming onto boost (2-3.5k) after that it pulls strong and feels good but in that range it lacks responce and just kinda stumbles and doesnt want to go sometimes if i give it more throttle itll like pop then start going other times if i ease the throttle its barely noticeable.
now im going to pull codes, take the timing cover off and check my timing as im runnign dual exhaust cams (intake advanced one tooth as in faq) and try to find my vac leaks, i read that possibly the dropping resistor might be causing the stumble i have a spare im going swap it in.
my butterflys are temporarily hooked up on the vac/boost reference till i wire the solenoid and install the chedck valves and canister.
im running walbro 255 and stock fpr (i know but out of moeny at the moment)i dont notice a rich condition no exhaust back fires, no black smoke a lil carbon smell from exhaust so its probably a lil rich.
im running bcpr6es plugs gaped at 1.1mm (.044) ..
sorry for the long post but wanted to make it informed to help u guys get and idea of the situation.
also how can i test the maf tube for leaks? also going to clean my maf but its the stock ca one with the adjustable screw.
i do not have a fuel pressure gauge and cant offord to buy one at the moemnt i might see if someone has one i can use but might be out the option for the moment.
oil pressure at 800 is about 20psi and 3k is 65-70psi. water temp stays around 180-190f
