new swap, gt28r needs a rebuild ALREADY???
Car: 1992 240sx coupe
Ok, I recently finished my ca18det swap and traded my T3/T4 and manifold from my blown ka-t for cash and a gt28r that I installed in place of the T25. I installed it together with the engine at the same time. Now, 200 miles later the compressor wheel is hitting the housing but the turbo doesnt smoke. Checked the turbo, lots of shaft play or at least alot of compressor wheel play as I only checked it from the compressor side so far.
Is it possible that the original oil feed line for the T25 is too small for the gt28r? Where did I go wrong? Did I get a bad trade?
The_Chosen_One
Car: 2009 Subaru Impreza 2.5i
is this a real GT28R, if the compressor wheel is hitting the compressor housing pretty much turbo is done. A GT28R is a ball bearing turbo and cant be rebuilt. The original oil feed line is fine.
Yes you got a bad trade.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
yeah, if its new though garrett will warranty it... but that does not sound like the case. ive been running a gt28r for several years and its been noting but a fantastic little turbo. ive always used the stock lines, and ive never had a problem with it.
dash
Car: s13 ca18
you made sure oil feed line was flowing before turbo install ? still flowing ?[email protected] (928) 453-7321ask him if he can help you & post back
When I checked the turbo b4 install I noticed a little shaft play but not to bad for a used turbo, but it sucks these things can't be rebuilt. I never checked the line for oil. I'm going to install a flex line this time to make things a little easier. Looks like I kinked the line to the turbo slightly but it was still enough space for oil to go thru. I also noticed the S15 feed line I got with the turbo has a bigger diameter than the ca18 line, hence my feed line question. Thanks for all the responses and info.
dash wrote:you made sure oil feed line was flowing before turbo install ? still flowing ?[email protected] (928) 453-7321ask him if he can help you & post back
Thanks, defintely will do.
