Possibly considering your diff is connected to your sub frame. If this doesn't then maybe get new differential mounts? No idea, just thought I would share.AZ89two4Tsx wrote:Will this help any with my welded diff?
Just wondering.
Oh, ok cool, I will just scrap the whole S14 project on your advice.ddgsxr504 wrote:S14 have "Y" shaped braces. So unless you plan on machining them out of a steel block I wouldn't bother cuz 2 flat "aerospace quality" MILD steel bars welded together won't do anything better.
...Welding is very strong... You can weld things together and then grind and buff them until it looks like 1 piece. You would not know the difference between 1 piece or 2 welded together...How do you think they make the "aircraft" made from the "MILD steel"? They don't CNC the whole craft out of 1 giant piece of steel...ddgsxr504 wrote:S14 have "Y" shaped braces. So unless you plan on machining them out of a steel block I wouldn't bother cuz 2 flat "aerospace quality" MILD steel bars welded together won't do anything better.
LMFAO I will be one of the first customers for the S14 one fyi.johngriff wrote:
First off I'm not knocking his product, it's just that the S14 brace is a bit more complicated than a flat piece of steel, the main nut for the subframe is recessed in to the brace.Space Monkey wrote:How do you think they make the "aircraft" made from the "MILD steel"? They don't CNC the whole craft out of 1 giant piece of steel...
John is making the product function how it should have in the first place. The OEM just made them too thin.
How do I think they make aircraft? Well for 10 years I have worked on FA-18A/D Hornets and now Huey/Cobra attack helicopters I can tell you there is VERY little welds holding an aircraft together nor are their any MILD STEEL components. It's mostly aircraft grade 6061-T6 or 2024-T3 aluminum with titanium and inconel thrown in the mix and it's all riveted together.Space Monkey wrote:How do you think they make the "aircraft" made from the "MILD steel"? They don't CNC the whole craft out of 1 giant piece of steel...
I'm no expert in welding, although from what i understand, the welds in steel products are just as strong as the parent material you used. So for MILD Steel, it would be a great way to make a connection. Now Alloys make a huge difference.ddgsxr504 wrote:How do I think they make aircraft? Well for 10 years I have worked on FA-18A/D Hornets and now Huey/Cobra attack helicopters I can tell you there is VERY little welds holding an aircraft together nor are their any MILD STEEL components. It's mostly aircraft grade 6061-T6 or 2024-T3 aluminum with titanium and inconel thrown in the mix and it's all riveted together.
You Fail.
cool, i cant wait to add ur subframe braces to my list of suspension components. i look forward to getting em installedjohngriff wrote:Witin the next week I am hoping. This run was done out of state. I was hoping that after a few done hands on, we could trust a lower cost out of state facility, but Quality control has been an issue because I cannot be "right there" to monitor it. So, its taken longer having samples sent back and forth at each progress step.
I will post up new pics when they are in, and notify everyone that has been waiting.
i ordered min before you did and still haven't received my set . i also tried contacting them and have had no response. they better come through soon, ive been waiting for the daysmikebluesrt wrote:Hey everybody. I'm just curious if anyone who has had these braces on order received them recently. I've had mine on order since October 23rd and that was close to the time John was having email issues. I still haven't received the braces. I've emailed him twice and he hasn't even emailed me back just to let me know the status on them. So, I've kept an eye on this thread and his website but now today it says the website is unavailable. I'm just curious to see if anyone knows what is going on.
Thanks in advance.
