szh »
https://forums.nicoclub.com/szh-u149.html
Wed Aug 02, 2006 5:49 am
I know that some people believe that setting the cross-drill sweeps one way (or the other) is better, but it really does not matter! I remember reading about some actual experiments (but can't find the references now for some reason) that showed no perceptible difference mounted either way.
So, I would not worry about it much. Certainly follow the Stillen or Brembo recommendations if you want to, but it is not important, IMHO.
Of course, if the rotor were a two-piece, with air evacuation nearer the hub as well, then I would consider making it work so that the air went "outward" on the vanes inside the rotor, as the car rotated forward.Z
