New STILLEN Big Brake Kit - 2-Piston - Coupe & Sedan!
Team STILLEN
Car: 2004 G35 Coupe
Just wanted to drop a note, we've introduced the STILLEN Big Brake Kit for the Altima Coupe and Sedan. This kit is an excellent bolt-on upgrade, and fits in the middle on budget between a rotor/pad upgrade and the full 4-Piston AP Racing Brake Kit.
Full detailed information is up on the blog: http://blog.stillen.com/2008/0...sedan/
This kit will be available late September!
Some brief specs:
* STILLEN / PBR 2-Piston Calipers (Black Caliper w/Red "STILLEN" script) * 13" (330mm x 28mm) 1-Piece Cross-Drilled & Slotted Rotors * High Performance Mintex Xtreme Brake Pads * Stainless Steel Braided Brake Lines (DOT Compliant) * All necessary brackets, hardware and instructions are included * Fits factory 12-spoke 17" OEM wheels * Fits both 2007-2008 Altima Sedan and 2008 Altima Coupes * Matching Rear Cross-Drilled and Slotted Sport Rotors (NIS5301XS) are also available
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
how much is this gonna end up bein ???????
