Racer_Ace wrote: ↑Tue May 22, 2018 10:06 pm
Ok so I have a 1990 300zx 2+2. Naturally aspirated of course. Original engine. The starter would sometimes spin and completely not catch the flywheel. It probably happened 60% of the time. Finally the starter eventually locked up. Wouldn't even turn over. So. Bought a new one. I go to put the new one in and find out the old one was only held on by the top not. Bottom bolt is gone. And the starter was shaking apart. Completely destroyed. So I found a bolt that fit the whole. I believe it's a 30mm long bolt. Worked just fine until I go to turn it over and it just grinds. The guys at O'Reillys tell me it's my battery. Said it was bad. So. Bought a new one. Put it in, I even replaced the little terminal for the starter wire on the positive terminal. GOOD CONNECTION. New battery. Still grinds. So we replace the starter again thinking it's defective. Nope. Still grinding. If I shook the car in gear it would sometimes start up just fine. But now it's not wanting to do anything but grind. my flywheel looks good. It's just a starter from O'Reillys. Can anyone think of anything wrong I might be doing? Do I need to shim the starter? Is there some kind of spacing that's required? I'm so lost.
Sorry to burst your bubble but, I'd never take suggestions from an OReily's employee.
Most likely that Oreily's sold you a bad/wrong starter.
I used to be a technician at my previous job. Every time we'd buy moving parts from Oreily's, it turned out to be a defective part. Those a**holes sent me 6 defective power steering pumps that I had to keep constantly changing on a clients car. What also made it worst was that they didn't have any on the shelf so they had to keep ordering pumps from the mainland. (I live in Hawaii)
I'd rather stick with NAPA or carquest.
P.S Have the parts guy use their battery tester on your battery before they give you an assumption.
One easy way I know whether if it's my battery or my starter, I just turn on the headlights and crank it.
If your headlights fully die out when you crank the car, then it's your battery.
If your lights just dim out a little, then it's a starter issue.
Good luck, hope you solve your problem. Come back with your findings.
