New started didn't cure starting problem
tumolt
Car: 1993 240 SX SE
My '93 240 SX SE has a problem starting. I replaced the starter, battery and terminals. The starter won't fully engage. I hear one click and nothing or sometimes it starts. I was told the main relay may be the culprit. I can start the car by using a jump wire off the positive side of the battery directy to the starter with the key on. Has anyone had this problem and what might be the root cause? Thanks, Matt
sigsterrr
Car: 1989 coupe p.o.s.
Check your terminals and ground connections. If you are getting a click from turning your key but wont start but can hotwire it from the battery then seems your connection to the starter from your ignition may be bad. Check the voltage going to the starter at the ignition and at the starter if the connections are good.
240roadz
Car: 1994 240sx convertible se
Yes i have had this problem i only changed my ignition switch n the problem stopped
WhiteKnight
Car: Nissan 240SX
Sometimes when the starter isn't working; I get 1 click. And if I turn the key and to ON about 10 times....then the starter works. It seems to do this only after driving around and having the engine hot. My starter is 6 months old
Cruz240Sx
Car: 89 Nissan 240SX
95 Nissan Altima
00 Nissan Sentra
had same issue before had wires fried from the ignition switch to the starter was so bad had to run new wires or have to tear into the wire harness. check the ignition switch first and got from there
S132o9
Car: 90 s13 kae
haha had the same prob i put a new one in didnt start come to find out it was the clutch sensor not engaging all the way!
