New Stainless LS1 -> S14 Mounts...
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
About time to get this turd back on the road...got tired of the old mounts and decided to step it up a bit with 1/4" Stainless TIG welded engine mounts, aluminum transmission mount and all stainless hardware...
kyhunter89
Car: 1989 240sx 5 speed
Looks pretty.
I've seen your videos on youtube for awhile...
I work at pan osten in bg.
cnichols
99 Infiniti Q45
93 Ford Fastiva
Good deal! Pan Oston orders from us at Airgas...in fact I just setup their online account a few days ago.
cnichols
99 Infiniti Q45
93 Ford Fastiva
greensx
Car: 93 240sx hatchback
Damn how much for a set
perf.element
Car: honda fit
bump for price
Blown240sx
Car: 1996 240sx
I think they are asking 400 or so. Ill tell Chris to post on here tomorrow.
cnichols
99 Infiniti Q45
93 Ford Fastiva
Blown240 is correct but feel free to PM for details.
240_KA
damn, this forum doesnt get much traffic huh?
chris what are your rear wheel and tire specs? the CCWs specifically, but if you have a new setup, i'd be interested to know those specs too. ideally it'd be cool to run a 295 or 305 rear tire so i'm trying to see what offset i need to run with a 10.5 width wheel so that it's not poking past the stock rolled metal (s14).
here is 17x10.5 +27 25mm spacer front, 20mm spacer rear
Front tire is 245/45-17, rear tire is 315/35-17
i'm thinking something around a 10.5 +35 would fit inside the metal and allow for some meatier tires.
cnichols
99 Infiniti Q45
93 Ford Fastiva
18" x 9" +19 (225/40/18) -.5* camber
18" x 10" +25 (255/35/18) -2.5* camber
Camber was not added until after these pictures were taken...they are probably very close to 0 in the pics below.
Chingon
Car: 1991 and 1992 hatchbacks
saw those, but wasn't a fan of the warping....thing goes to where it should once bolted I take it?
Chingon
cnichols
99 Infiniti Q45
93 Ford Fastiva
Warping is only present on those pictured...which were prototypes. I have used those on my personal car for that past year with zero problems. Once we acquired a one inch thick piece of steel to bolt them to while welding and act as a heat sink, we have had 0 issues with warping.
Return to “Hybrids”
