New SR coilpack cover, opinions....
skillzilla
I have a friend developing a new coilpack cover for rear-drive SR's, wondering what everyone thinks. Here are some pics, first couple of pics are the production part, the last ones are a test piece installed so he could check the fitment.:
nwmrkt
Car: S13
those actually look pretty cool.
efrain240sx
Car: 1992 nissan 240sx HB
It looks good, but will it clear splitfire coil packs ?
FAST-DATSUN
no vents??? heat iis the probelm that causes coil failures
skillzilla
efrain240sx wrote:It looks good, but will it clear splitfire coil packs ?
Hmm, not sure on this. How much taller are Splitfire coilpacks? I can check the clearance vs the stock pieces and let you know...
skillzilla
FAST-DATSUN wrote:no vents??? heat iis the probelm that causes coil failures
It has vents down both sides, is that what youre looking for? That, or more vents on the top portion?
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
I'd like it better if it was a little bit thinner so that the parts that the screws go into sit flush with the valve cover.
fc3sdrifter121
I like it,but I wouldnt spend more than like 40$ on it
corey240
Car: 1993 Nissan 240SX Base Drift Machine
redtop91 wrote:I'd like it better if it was a little bit thinner so that the parts that the screws go into sit flush with the valve cover.
he said thats not the actual piece just test fitting somthing befor production pieces
GTS4-R
Car: my feet
im not feeling it....but i LOVE your valve cover!
CMG
Car: 1989 240sx Hatch w/ Redtop
If I could make a cover I would either make one out of high temp plastic, or a metal one with vents down the middle of it, kind of like a grill. I almost bought one of those HKS powered metal covers, but when I checked it out it was heavy as hell and had no venting so it would cook some coils fer sure.
Sabot
What about the s14 sr?? but nice looking cover for show points
