SRJesse »
https://forums.nicoclub.com/srjesse-u987.html
Tue Mar 18, 2003 1:06 pm
I have a HB and have put 4x6 infiniti kappas front/rear then custom mounted 2 6x9's in the hatch cover connected to an amp. The 4x6's are so crisp and clear with the highs, and the 6x9's give the touch with the mids/lows and the bass. You can definately cut out some of the door with a dremel tool, but there would be alot to drill out to fit the 6x9's in the front. In the rear not sure what you could do, you could always mount them underneath the rear little window in the HB, I was thinking of putting another set of 6x9's there too! GOOD LUCK...
