240life »
https://forums.nicoclub.com/240life-u76914.html
Sun May 11, 2008 1:04 pm
Ok the image above should help with the info I got out of the Fsm...if it doesn't test this way it is no good. 1) disconnect power transistor harness connector2) check ignitor continuity between terminals with analog tester+E/ -1 should have no continuity same for +E/-2 etc.... - E/+1 should have continuity same for -E/+2 etc....... +E/-A should have continuity repeat for +E/-B,C,D. - E/+A should also have continuity repeat for -E/+B,C,D. +1/- A should have continuity procede to +2/- B,.. +3/-C,.. +4/-D -1/+A should have no continuity procede - 2/+B,.. -3/+C,.. -4/+DIf done like this you need a multimeter...if you don't have one... leave it connected to your harness and test in the same fashion using one of the cheap light-up testers
Modified by 240life at 4:37 PM 5/11/2008
