new spark plug ???s
p00t
i just aquired a set of NGK iridium spark plugs for my ka24de
i installed them and then started the car, idled for about 2 min then shut it off and went inside... when it dawned on me...
Do they come with the correct gap from the factory? (got it through PDM Racing specifically for that engine)
when u first get spark plugs are u supposed to adjust the gap or are they fine to begin with? sorry for the n00b question :pface
Holisticbeatz
I'm not sure if they come pregapped, but you should do it anyways to be on the safe side.
Kinesthesia
I'm pretty sure they are pre-gapped... my Denso iridiums came with plastic covers over the ends to prevent something hititng the end of the plug and changing the gap. If yours had something similiar they were probably gapped properly.
trpower7
Iridium plugs on an NA car = WASTE OF MONEY.
p00t
trpower7 wrote:Iridium plugs on an NA car = WASTE OF MONEY.
they're like $1-$2 more than platinum..... and i needed new ones anyway, it wasnt an upgrade. ill pay 6 bux extra for peice of mind, thanx.
Kin yea your right, i did have covers over them to protect the electrode. good call! and i guess ill rip one out to double check :X
WorkinDriver
Car: 240's
Most platnium plugs come pre gaped... But he's right you should still check them.
Toahk
Car: 97 ....
Dont think ive ever seen a new spark plug come without the plastic cover, ive always had to gap them also. I dont think they come pre-gapped
180fan
Car: 89 fastback
do NOT gap those iridiums. You will snap off the conductive material on them. They come pre-gapped from the factory and do not need you to gap them and more likely than not break them.
mattback
Car: being a big f'ng ricer
yes, you need to gap your iridium plugs to whatever your setup is.
on a turbo car, gap them to .028. do NOT do this by banging the electrode on the ground to close the gap. this is how idiots break the conductive material.
are they BKR6EIX-11's ?? That means they are gapped to 1.1mm ,or approximatly .044" from the factory.
p00t
UPDATE:
i checked the gap and confirmed it is the correct size. Hurray i dont have to screw em up now! who knows what gapping method i would have tried!! :D :D :D
sorry i brought this whole confusion up, i ordered it from pdm so they already babied me through the process by picking the size for me. aparently i didnt understand the diff various codes, didnt know plugs came like that... DOH!!!!! Learn more each day...
NiTeRiDeR
Car: Z32 + D21 + 2x R32
if you are told NOT TO GAP the plugs... then they come to factory specs... but i would check anyway
i think the only plugs you dont gap
are platinum 2's and 4's
Nismo_Freak
Car: 89 Nissan 240SX
You have a small range you can regap platinum plugs... once you set them you are not supposed to re-gap them.
float_6969
I don't know jack about sparkplugs either. I'd like to learn more. I've heard of going to "colder" plugs when you turbo and such, but I don't really know what that means. Any one want to enlighten us, or atleast direct us to a good site? (Sorry for jackin your thread poot)
p00t
quite alright
how stuff works explanation on hot and cold plugs, if u wanna skip some info just scroll down alittle and it will explain with pictures the diff between hot and cold plugs.
SPARK PLUGS
trpower7
I don't understand what you mean by "peace of mind", that makes no sense, in no way will an iridium plug provide any kind of protection over malfunction than a platinum plug or even a regular NGK plug for that matter.
float_6969
Hey poot, thanks for the link. That explained my question perfectly! I always forget about that site. I bookmarked it this time though.
