Obviously this topic has been beaten to death, so I'll start by saying yes I did search, and I did find
some valuable info.
My brother in-law wants a new sound system installed in his 2001 Pathfinder SE for Christmas: head unit, all four door speakers, and possibly a single 10 inch sub (although the sub takes last priority). I told him I would research what is needed and try to find some write-ups on the install. I've installed a few head units before, and set of door speakers once, but I wouldn't consider myself an expert in any way shape or form.
I believe his pathfinder comes stock with the Bose system. I've read about it on other threads (my Z came stock with a similar setup); however, I'm unfamiliar as to what problems this causes while attempting to replace the system (i.e. what extra hardware will I need to remove/replace the stock Bose setup?). From reading other threads, it seems that most advise rewiring the sound system. Does anyone have a writeup for this? I've never attempted this, but I can imagine it is quite a pain in the a**. Are there wiring harnesses available for this vehicle which will allow me to skip rewiring, in case this proves to be too large of a job for me? Also, I found a writeup on removing the door panels for a '99 QX4. Is the procedure identical for removing his door panels and does anyone have a better writeup? The FSM is somewhat difficult to follow, but I'm sure I can manage with nothing else available.
Next, can anyone recommend a setup? I am familiar with brand names, but I've not had much experience with many in particular. The only contingencies for the system are that the head unit has an auxiliary port (ipod connection would be nice although not required), and can reliably push loud volumes. We're looking for a system within the range of $300-$400 - if this is feasible. Is it pretty standard to go with components in the front and standard speakers in the back?
This recent post lists the Kenwood KFC-P709PS speakers. Can anyone recommend a better speaker around the same price?
Questions:
1) Besides the speakers themselves, and obviously the kit for fitting the new head unit, what else will we need to install the new system (e.g. speaker mounting brackets, amp, wiring harnesses, etc.)?
2) Are there any write-ups for the installation; specifically the rewiring process would be most appreciated. Write-ups for removing the door panels (more clear than the one listed in the "How-To's" thread), installing the speakers and installing the head unit would also be appreciated.
3) Can anyone recommend a decent and complete setup for between $300 and $400?
