New shoes on my 2005 F50!!!
Bigmike40
Car: 2005 Infinit Q45
They are 20" X 8.5 all around. I was going to stagger the rear but the tire replacement down the road is expensive. I like the new look, just need to lower the front, even with 20" rims the front still looks like a 4 X 4.
Mike
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Weight, strength, offset, hubcentricity?
Tire size, speed and load ratings, weight?
That will tell us more how they work on the car than how the look in the driveway.
Bigmike40
maxnix wrote:Weight, strength, offset, hubcentricity?
20 Inch Lexani N3000 Tires Summer Tires:The Lexani N3000 is an ultra high performance (UHP) tire designed for superior performance without sacrificing ride quality. With fitments for the curve-carving tuner to the street cruising sedan, the Lexani N3000 is the tire for your performance car.Features:
Silica based tread compound offers superior high-speed durability, lower rolling resistance and increased traction.Large center tread block delivers high-speed stability and a smooth ride by absorbing impacts from imperfections in the pavement.Large tread blocks on the edge of the tire improve cornering by resisting lateral force, keeping more of the tire on the pavement. This also improves performance “at the edge” providing a clear feel for the limits of adhesion.Single wire bead construction offers improved strength, ride comfort and steering stability.Aggressive V-shaped tread pattern offers excellent water dissipation for wet traction.
Tire Size UTQG Rating Speed Rating Load Rating Sidewall Style Per Tire
255/35R20 XL 340-AA-A Y 97 BSW
The rims are made by GWG, 20" X 8.5 with a 38MM offset. As far as weight, I will let you know, I will compare them against my stock chrome 18" rims. The link to the rims: http://www.gwgwheels.com/wheel...Amaya
Mike
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Thanks. Never heard of Lexani, but at least they are load rated adequately.
I always worry about wheel manufacturers who so not disclose weight and strength upfront. Especially if the wheels feature fake rivets and bolts, one knows that weight vs. strength was not a consideration.
Always interesting to see which wheel and tire manufacturers participate in sanctioned racing competition and at which level.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
They look pretty good. I think they suit the car nicely.
NightRiderQ45
Car: 1998 Infiniti Q45
maxnix wrote:Thanks. Never heard of Lexani, but at least they are load rated adequately.
They are the same people who makes Nexen tires...which are great tries.
Q45tech
The Hunter 9700 is the only PROVER of whether a tire is decent or not, if it doesn't exceed the 5.0 pounds of Radial Force.I have seen brand new import premium [so they say] tires exceed 50 pounds........10x worse than spec and they try to sell them for $250 each.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
NightRiderQ45 wrote:They are the same people who makes Nexen tires...which are great tries.
Oh yeah, they participate in the.......which racing series is that again?
apossiblehybrid
Car: 1994 Q45
be careful, those look like poor quality wheels.
unknown007
Car: White 1993 Q45 (G50)
Not my style but looks great.Don't be scared by the comments you get.
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
I think you did a nice job, they look good. I feel bad for you come tire time (again).
Q45man1
Car: 2002 Q45, 1994 Q45
It looks good. Your white F50 looks nice with the chrome rims. Mine is riding with swift springs.
Chrome + white go together well, along with your dark tint.
Bigmike40
unknown007 wrote:Not my style but looks great.Don't be scared by the comments you get.
Thanks, I'm not scared of the comments. They are just that "comments", you will never please everyone, just as long as I am happy. Also its my car:-)
Mike
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
Lexani makes a very good quality wheel. The 38MM offset looks clean too...could you take some side pics of the wheels so we can see how far they protrude outward? The staggered look is sweet but will be expensive in the long run because of rotation limitations.
BTW---do you have your TPMS sensors installed on your new wheels?
Bigmike40
seldomseen wrote:Lexani makes a very good quality wheel. The 38MM offset looks clean too...could you take some side pics of the wheels so we can see how far they protrude outward? The staggered look is sweet but will be expensive in the long run because of rotation limitations.
Thanks seldomseen. I do have the TPMS sensors in the wheels. I will take pictures today when I leave work, the rims don't stick out beyond the fenders but they do look better!
Mike
seldomseen
What brand lowering springs did you have in mind? I wonder how the Q will handle with only front lowering springs installed. Does your Q45 have the "active suspension" feature?
Bigmike40
seldomseen wrote:What brand lowering springs did you have in mind? I wonder how the Q will handle with only front lowering springs installed. Does your Q45 have the "active suspension" feature?
I don't know of any springs but swift. I lowered my Maxima (front only) because it is set up like the Q and it was great. I also swapped out the struts and shocks in the process. I got the active suspension system, I probably wont lower the car because I would destroy the suspension.
seldomseen
I'm not personally familiar with how the active suspension feature affects getting lowering springs or coilovers. I just read that repairing or replacing the A/S is a TON of MONEY!!!
Bigmike40
Mike
Sorry they are late but here are a couple of rear shots of the rims. AS you can see they don't stick out past the fenders.
Mike
seldomseen
Sweet picks Mike...where do the wheels line up with the inner fender? Are they behind the inner fenders?
Bigmike40
seldomseen wrote:Sweet picks Mike...where do the wheels line up with the inner fender? Are they behind the inner fenders?
They are little behind the inner fenders.
seldomseen
I think that's an excellent size and offset then! You will never had to worry about rubbing even under passenger weight load then.
HG50
Car: 91 Q45
15 4Runner
looks like your floating on air from the back! put some good spacers on that and it'll look a lot better.
