Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Nov 03, 2009 3:33 am
Did you check wheel balance without tires? These early wheels were replaced by the hundreds due to out of spec bending [soft cast] , leaking, and vibration.
Spin them up without tires and make sure they show less than 5 grams imbalance outer and 10 grams inner imbalance..............on fine not coarse balancer setting.
Per wheels without weights and perfect tires with small weights make for a perfect ride unless you chose Goodyear or other lesser tires.
