new shocks & rubber parts effect on alighnment
captainluigi
Car: 1996 q45t
will be replacing o.e with tokiko blues & pilot exaltos this month. am planing to do shock replace over 2 wknds. what effect if any will the shock renew on the alighnment specs? i thought i would replace tires first or do i have this sequence wrong?
Q45tech
Anything that changes body height will change camber.Only tension rods, upperlinks, 3rd links, rack bushings and any rear suspension arms will change alignment.New shocks with new mounts might decrease camber a tiny bit.
Front and rear Toe [thrust angle] usually change the most frequently why every 6 month alignments are recommended.
qship96
Car: 1996 Infiniti Q45
Did you get the 225/60/15V Exalto on sale at Tirerack?
captainluigi
Car: 1996 q45t
thanx dennis.
qship96; no i ordered the o.e.size 215/65 H 15 exaltos. i do not really need a V rated tire. 55miles in either direction and the limit is still 55mph. my car sees maybe 90mph 1 or 2 times a year. well there is this one bridge 7 miles long and in non tourist season, well things do happen. anyway after reading your post about tire wear i checked tirerack online but no sale price listed. do you think the 225/60 is a better option? my tires are on back order for 4 weeks., they said i could change or cancel or whatever. soooo, if there are convincing arguments for the 225/60s i am interested.
GseaQ
Hi Captain,
The only downside (and it IS marginal) is the slightly smaller diameter of the 225/60x15 - maybe 1/4", maybe less - 806 vs 812 RPM. The pluses are:
V speed rating which will give slightly sharper steering - maybe not that noticeable to some, unless they've driven the same model in H rating recently for comparison
slightly shorter sidewall (helps the sharper steering) looks better
a tad wider footprint
Why wait for the backorder?
Glenn
captainluigi
Car: 1996 q45t
point taken, thanx.
