any thoughts?GTR PrYdE wrote:Couldn't you just retard the timing "X" degrees, and leave the fuel to the N60 Maf? Therefore using the N60 with 370cc's instead of any fuel management
Huh? If you change injectors and MAF you will need to correct your fuel. For 7lbs there is no need to change the MAF. In fact, there is no need to make such a big deal of it at all. One could almost get away with an FMU and use the stock injectors - I wouldn't recommend that though.GTR PrYdE wrote: any thoughts?
But what ever.
