darinz »
https://forums.nicoclub.com/darinz-u47224.html
Thu Dec 27, 2007 10:26 pm
Link is good for do it yourself as they give heaps of support to the end purchaser. But they are unreliable and I'm not prepared to put up with half arsed gear, particulary when it has cost $2k. The Autronic has cost about $3500 but when ou take into account dyno time at $120 an hour, the Auntronic becomes a cheaper option very quickly.At present the ecu has limits set for map, engine temp and intake temp. I don't what other protection you need? I also can have antilag as is standard feature but I don't use due to being an auto.The bigest thing ou get with a higher grade ecu is reliabilty and ease of tuning, if the right person is doing it. Once the setup was done and the truck was ready for power runs, it took about 2 hours to tune it, and the only thing that isn't setup properly is the over temp limits are set to 4000rpm. That is more a use problem as on the track that would be noticed very quickly but offroad I can spend a lot of time below that but still working hard.
