I have exact same seats in my car. Don't like the pattern at all since it doesn't flow with the vert interior material/pattern, but one day I'll redo whole interior. I also like vert doors. Seatbelts have easy access and I think pillars are one of those signature pieces on 240 vert.zenkii wrote:looks pretty awesome, also you even took off the door for a clear image
Good point. Yes, I do have this problem. It's not that bad, but seat won't move forward if you pull the knob because top got wedged against rear interior trim. I think this problem will go away once I swap the transmission to 5 speed because I' won't be able to seat like that anymore to shift gears.biggie wrote:Thought there was an issue with S14 seats in a vert. Like that they are too wide at the top and hit the rear panels (so you can't lean back too far).
