johnny butt »
https://forums.nicoclub.com/johnny-butt-u81072.html
Mon Dec 22, 2008 4:04 pm
Okay, so I've been doing some research for a while, gathered a parts list and estimated costs of different brands. I decided to go with SPL even though they are more expensive and probably more than I need to DD with but I also plan on eventually tracking the car so I don't see any sense in getting cheap suspension to begin with.
I am going with Stance GR+ Pro coilovers. SPL Toe Arms, Traction Rods, and RUCAs in the rear. SPL Tension rods, tie rod ends, and tie rods in the front.
I had also planned on replacing my subframe bushings with SPLs aluminum bushings as well as getting some new differential bushings.My question about that is: Is dropping the S13 Subframe similar to dropping the S14 subframe, or are there any extra steps/precautions I should take into account?
From the looks of things, it seems like it shouldn't be any different. Do I have to drop/separate the differential from the axles?
Also, I am not going to be able to do an alignment myself obviously, but I was wondering if when I put all of these new arms/parts on, would it be okay to drive 40-50 miles to a shop, or should I just have the car towed there? Aside from an alignment, I am not sure what all (as far as adjustments) will have to be done to ensure a safe trip to an alignment shop. Any help or insight would be appreciated.
Few additional questions, but they are cosmetic issues and not that important:I had also planned on painting/touching up the subframe and differential cover. Is there any specific type of paint you guys would recommend or would the rustoleum in a can work just fine?
Thanks.
