rioredstang »
https://forums.nicoclub.com/rioredstang-u121266.html
Sun Oct 25, 2009 2:49 pm
It's hard to say with limited info. You should start by checking for codes. Lack of power could be slow timing, bad air flow meter, low fuel pressure. Make sure that the intake boot between maf and throttle body doesn't have any tears or leaks. Pull the plugs and look at the tips. Are they black and sooty--rich, are they white--lean condition. Check manifold vacuum at idle, if low could be cam timing. If you can get some of the answers then we can go a little farther.
