jamesmost »
https://forums.nicoclub.com/jamesmost-u8573.html
Mon Jun 18, 2007 4:36 am
BF GOODRICH g-Force T/A KDWS uses a new tread compound molded into an asymmetric tread design with large, stable outer shoulder tread blocks to enhance dry traction while its inner independent tread blocks enhance wet road grip and light snow traction. Together, the tread compound and tread design help evacuate water from between the tire’s contact patch and the road to enhance wet grip when braking (it earns the highest "AA" UTQG Traction Rating) and cornering. Internally, the g-Force T/A KDWS’s polyester cord body incorporates BFGoodrich’s g-Control Sidewall inserts to enhance steering response and twin steel belts to deliver cornering stability. Additionally, the steel belts are reinforced with BFGoodrich’s ETEC (Equal Tension Containment System) spiral wound nylon to provide high speed durability while minimizing weight and maximizing ride qualities.Arriving today will be on this week - YEAH Size 245/45 ZR17 95W SL UTOG 400 AA A Max Load 1521 lbs.Max INflat 44 psi Tread Depth 10/32" Weight 27 lbs.
