My usual dumb questions of the day (so what else is new from me!
How and where is the runout measured? Along the edge of the rotor or perpendicular to the rotor face somewhere? In other words,is it a thickness variation issue or a diameter variation issue when the wheel is turning?
If a diameter variation, how does this minute amount of offset mass affect the cars braking? Heck, out of balance tires would be a bigger deal!
So, how exactly does the shim work in the correct scenario above - does it sit around the hub (braced by the lugs, I suppose) and move the rotor a tiny bit in the plane of the rotor? Or does the shim actually tilt the plane of the rotor a tiny amount?
Thanks for any education you can give me!
Z
