AlabamaDan »
https://forums.nicoclub.com/alabamadan-u438.html
Tue Sep 04, 2007 7:33 am
I've got new pads, and good clean shims.
The rotors are at the shop getting turned and the guy sounds like he knows his stuff. Runout, minimums, etc.
I've cleaned up all caliper parts, especially the caliper brakets, bolts, etc. I worked hard to clean that little hole where the caliper slide pins go. I'll be really stuffing it with good high temp brake grease.
Should I use anti-sieze anywhere? I was thinking about those 17mm bolts that hold the caliper braket in. Could it be put anywhere to help the rotors from being so hard to pull off later as they are from time to time?
I'm excited about getting this fixed. That should put the old Q back on the road for the first time in months!
