AcMav »
https://forums.nicoclub.com/acmav-u86256.html
Tue Mar 04, 2008 3:43 pm
To Start Off, Brake Performance is a Controversial Issue, Everyone has a Preference on Slotted vs. Drilled vs. Blank and they all come with their pros and cons.
Unless you plan on driving your car on the track theres no way you need slotted or drilled rotors, They're just way too expensive for what they're worth. I Use Hawk HPS with Brembo Blank (Non-Slotted/Non-Drilled) replacement Rotors and they stop plenty fine. I consider myself a spirited road driver and I've never found myself saying Ooh i wish i had those slotted or drilled rotors... They're easier to break/warp and cost way more to replace for little to no gain. I say stick with the blank rotors, $36 vs. 70-80, take your pick, for me it wasn't worth it. This decision for me was based on the advice of a professional car builder and racer who suggested i save that money and spend it on stainless lines to see a greater performance gain.
Another upgrade you may consider doing is upgrading your brake lines to stainless steel because they don't expand under heat/pressure like the normal OEM lines do. And Surprisingly, for the really cheap, a 6 dollar can of Brake Fluid can make a difference if you're using old fluid.
I Personally spent 400 in total getting 4x Brembo Replacement Rotors, Set of Hps Hawk Pads and Stainless Steel Brake lines.
