ImStricken06 »
https://forums.nicoclub.com/imstricken06-u194849.html
Wed Dec 07, 2016 6:42 pm
the good:
the engine is solid, dating back to 2008. we all know this engine is time tested, starting from the old sentra.
the awd system is amazingly well designed. i got my 2008 rogue stuck in snow, i swore i was done for - and the rogue got out without an issue. i dont know what they use, but with the right tire combo, the awd kicks major butt.
the bad:
the transmission = leaves a lot to be desired. its common for issue, its now less common to replace. but the chance is still out there.
the interior build quality is poor. the 08-12's were known for the cheap plastic, rocking driver seats, loud cabin noise, stiff ride, etc. it felt like driving the PT cruiser.
the 2014+ radio/infotainment units i hear suck. major lagging, needing constant resets, etc.
small things constantly failed: headlight adjustment motor, pcv valve, evap valve, gas cap, brake light switch, gear shift solenoid, (all under 60k)
weak heat
weak a/c
the ugly:
the brakes. OMG - i have never seen such piss poor quality brakes. look back at the history on here, and you will see that grandparent-style drivers were getting 30k out of their pads & rotors. did i mention the calipers have faulty seals, leading to costly repairs? ya- i had to change all 4 calipers, rotors, pads, prior to 50k.
the front CV axles - fail at around 75-90k. idk what it is, but the half-shaft seizes in the small carrier, and that makes for a nightmare. in fact, a member on here (who also follows me on instagram) just faced the same issue, and called a quits - and traded it in for a bmw. i get messages all the time about these darn fron cv-axles.
the transmission goes into limp mode, out of nowhere. usually mid intersection, where people almost got killed. this is well documented on here. its either the transmission or the brake light switch.
the transmission whines, when in hot weather
the transmission goes into limp mode, when its hot outside, and you are on hills.
final words: i know i spoke a lot about the 2008 styles, but not much has changed other than cosmetics. the 2014+ is nothing more than lipstick on a pig. buyer be warned. tell her to check out the new hyundai tucson - its gorgeous.
