zero_gripS13 »
https://forums.nicoclub.com/zero-grips13-u21031.html
Sun Feb 08, 2009 4:10 pm
ok i order a set of new rod bolts and as with all rods that are not guided (guide pin) when u install new rod bolts u have to check to make sure the big end is still round and circular. well my question is since if there are not still round they will probably need to be honed to be round, so.
does it usually affect the rod clearances as i already have my bearings and was wondering if i might need a new set, or is the amount removed to fix it to minute to mess up the bearing clearances.
