Hmmm ... any chance could you have rolled it instead? The "cutting the lip off" may have weakened the fender edge to the point where even a minor "door ding" could show worse than usual?jadeM45 wrote:Required cutting the lip off the rear fenders. I drove it to work today and it looks like I will need to cut a little further down than I did.
Okay ... understood. If it has worked for you before, then that is all well and fine.jadeM45 wrote:I left a bit of the "roll" on there. So you can't tell from the outside. It will also help with the integrity.
I have many friends who have done this technique on many cars. If done right it works better than rolling in my opinion.
Here is the link to the thread about my spoiler.M45Caliber wrote:JadeM45 -- WHERE did you find that rear spoiler? That's exactly what I have been looking for (not the wing). Wheels look damn good - hope the fendr clearance works out for you --
Thanks for the advice. I checked everything out in the rear and i only need a little more trimming on the sides of the fenders. There is no more clearance issues other than that.CakeDaddy wrote:There’s that word again… “Flush” The car is looking good. I can’t wait to see the lower trim painted to match, but take note of the black strip along the bottom of the doors. That piece is rubber and may be hard to paint. As for the 20x10.5 in the rear… I was talked out of anything above 20x9.5 in the rear by my installer due to possible rubbing issues, especially since it was already lowered. As for the rubbing while turning… Be careful and I would advise against cutting the inner rear fenders but other than that the car is looking smoooooooth
cool, sounds like you have a plan. What method are you using to cut the inside of the fenders? I was thinking if you use a small grnder wheel... then maybe you can save some of the integrity(sp) of the walls, but thats just my opinion. Keep us posted my.jadeM45 wrote:
Right now Im doing the super carefull driving with wide turns etc. No rubs unless I go hard. This weekend I am going to finish up the trim and then it goes to the painter.
I have done the fender trim on previous cars with no issues. Other friends have to. The things some of us go through to get the look we want I guess.
