New rebuild. Spark, compression, fuel, but no start
pella
Car: 1995 240sx S14
Ok, heres the deal. I have a 1995 S14.5, automatic transmission with a KA. We have been beating our heads up against the wall trying to figure this out. When I got the car almost 2 years ago the head gasket was blown. We pulled the engine. Rebuilt it, all new bearings, pistons, rings etc. everything but the rods, crank and timing chain. I even got a new head for it. It’s been a long process. The one thing I didn’t replace was a horseshoe shaped, formed “bypass” hose that goes from the top of the air intake, to the block. 14k miles later, this hose destroyed itself on the fwy. that was 2 weeks ago.
It overheated so fast that I never saw the temp needle move. I towed it to my friends shop and she’s been there since. We thought this would be a perfect opportunity for a 5 speed swap, since we had to pull the motor anyway. The rings were shot. The head gasket wasn’t blown, I had a cometic three layer on it. I have always run royal purple oil. The motor got so hot that the spark plug wires were melted in the head. The valve cover blistered my finger when I pulled the oil cap off. So I bought all the necessary parts for the rebuild, and for the 5 speed conversion. We Replaced upper and lower timing chain. Tried to replace everything we could with new parts. I took the head to a local machine shop and they resurfaced the head, taking off .015. We removed the clutch fan and added electric fans. Over all I have been happy with the way things have been going. Everything is done and put back together. Looks good, nice and neat, and clean :) .
The problem is, it wont start. We have been working on the no start issue for 2 days now. We cannot figure it out. We have spark, fuel and compression. Timing has been checked, rechecked and double checked. There is only 1 code coming up, P1605 which relates to the auto transmission. We have tried three different distributers thinking maybe the cam angle sensor isn’t functioning properly. Tried 3 crank angle sensors and I’m sure they have tried multiple other things. We have access to quit a few parts for troubleshooting. My distributor has a new cap and rotor that I replaced about 3k miles ago. Its very strange. The spark seems really weak, it’s orange in color and does not seem consistent at all. Not sure what to try next. Please, if you read this and can think of something let me know. Any ideas would be appreciated.
pella
Car: 1995 240sx S14
Still have a really week, eratic spark. Anybody have any ideas on what could cause this?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Use the FSM and check the values for the troubleshooting section, check and clean connections and try a coil.
pella
Car: 1995 240sx S14
What coil do you mean? Actually looking at fsm now. Thanks
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
I assume this is a KA so it should have a ingnition coil aka power transistor.... make the spark
pella
Car: 1995 240sx S14
It has a KA. Isnt that internal in the dizzzy?
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
S14's distributor has an internal coil, S13 is external. Your weak spark has to be the culprit, like OutToWin said, go through the troubleshooting procedure for the ignition system, checking all the values along the way.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Ahh didn't know that part of KA. Yeah FSM is the way to go
