new rear end???
A home for 1983–1989 300ZX owners!
p03tic_mind
Car: 1985 nissan 300zx turbo
does anyone know if there are any positrac rear ends that i can put in my 85 300zx without alot of fab work
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
"posi-trac" is a trademark name used by GM for their LSD's, the 87.5-89 300 ZX came with a Clutch Type LSD that bolts right into your car, you might have to swap over your pinion flange but otherwise a direct replacemnt, same long snout R200 housing and carrier, the gear ratio's might be a bit different, they were 3.54 IIRC
sharjt
Car: '06 G35 Sedan 6MT
'83 Datsun 280zx turbo - RIP
I have a 87 cluth type direct bolt in for $800.
Perrenial Badass
Car: 1973 240Z, 1986 300ZX, 1987 300ZX, 1984 Corvette
The 88 Shiro Special came with a VLSD. There are also several aftermarket ones if memory serves.
evildky
06 Nissan 350Z GT
the viscous requires the viscous output shafts, cv shafts and companion flange, aftermarket units are carrier only so you have to have the ring gear installed and the pinion depth set
Return to “300ZX (Z31) Forum”
