new radio i need to figure how to fix some problems
nyvenom30
Car: 98' Nissan Maxima
i had a alpine deck in my 98 maxima it worked fine in my car no noise's and the regular radio worked fine.... when i put my new deck a dvd liner phase i got static noise that wasnt there when i had the alpine in... and for some reason when i plug in my xm radio i can hear my car reving up and down and the harder i press on the gas the louder it gets... also my fm radio doesnt work i cant get any stations.. i really pissed about this it really annoying me... please if you can help please do.. thanks for your time...
texmax
Car: 2000 Nissan Maxima SE
Are you using any amplifiers? If so make sure that you RCA's are seperated from your power wire or anything that had power to it. Make sure you have a good ground. Try running a new ground to the chassis of the car instead of the ground in the harness and also make sure that if you use a ground where there is paint to scratch the paint away before screwing it in. May be a bad radio. We had alot of bad luck with that brand when I sold it. Hope this helps.
nyvenom30
i yeah i understand that the rca gotta be sperated... but why is it that i got a screaming noise when i plug in the power to the xm radio... i hear my engine through the speakers... and the faster i go the louder it gets.. but its only when its plugged in other wise its a little static in the back around.. could it be from the ground going into the ciggarette lighter from the radio.. but the radio that i had before didnt make this noise.. im really frustrated with this cause it annoy the **** out of me... please if anyone has had this problem and came up with a solution please let me knoe thanks...
davskins97
Car: 2001 Nissan Maxima SE
Engine noise almost always comes from the ground wire(s). I had a similar issue with my car stereo. I had 2 newer alpine amps and 1 older phosgate amp. The phosgate amp had engine noise and the other 2 didn't. They were all grounded in the same place. If the amp sees too much resistance to ground you can get noise. I think the circuitry in my alpine amps is better and they are more resistant to noise. Your alpine hu was probably just a better piece of electronics than your new hu. You may need a better ground to get the noise out of this hu. I ended up moving my sub amp ground to a different spot and ground off all of the paint. I ran better ground wires (I was trying to use speaker wire) and removed the paint from the original grounding point. Mine went away almost completely, I can live with it because I can't hear it unless I have my ear by the speaker. The longer ground wires are and the thinner the gage the more resistance and possibility of noise.The noise you have is alternator whine. It is very annoying. I would try regrounding all of the items at your head unit that have grounds. I don't think the factory ground wire is considered to be a great ground. Your grounding point should have no paint or rust and would be best the bolt through the ring terminal(s) went directly to the frame. You may need to try grounding it different places and ways such as 2 different points for the 2 devices. Unfortunately, this is the single biggest pain in the *** problem you can get with aftermarket components. Here are 2 links that will help you better understand what you are dealing with:
http://www.termpro.com/articles/noise.h ... 999502.pdf
I say this with all sincerity...GOOD LUCK!
blazncypher
Car: 01 I30
if you got a crappy unit it could be your connects to your unit or when it got rewired they hooked it up badly. what kind of deck is it exactly?
nyvenom30
liner phaze uv 8... i think its a ground issue any suggestins where to ground the deck
