FriedEGs »
https://forums.nicoclub.com/friedegs-u28026.html
Sun Aug 12, 2007 12:05 pm
UPDATE:
Okay, I ran of series of tests.. basically what Darius suggested.
Eccs Relay harness plug: Voltage good (11.40)Eccs Relay: when voltage applied, ther was 11.40 volts going throughIgnition Relay harness plug: Voltage good (11.40)Ignition Relay: when voltage applied, there was 11.40 volts going throughIgniter: Voltage good (11.73) I checked this by grounding the middle wire of the 7 going into the chip, and power through the 2 wire plug next to the igniter.Coil pack harness: Voltage good (11.73) tested at #1 and 2 cylinders.Crank Angle Sensor: when rotated, fuel injectors fired! (bang included!! What happened? Did the fuel combust on the pistons that were near tdc? Kind of like a diesel?)
(All voltage readings were through the harness, and not through direct battery power or direct ground)
What I have NOT checked. The signal wires on the ignition harnesses. (the 6 pink wires) Also, I have not checked for resistance or continuity between the relay's and the harness for the ECCS and Ign. relay. I have not tested the Coil Packs, either.. I still need to figure out how to test all of these properly.
At this point, I suspect that the ignition sequence signal is not reaching the coilpacks... Or, at least, the coilpacks aren't transmitting the signal for spark down into the plugs.. (plugs are brand new)
