^ couldnt have said it better.....
Once a NICO addict, ALWAYS.. Its contageous and often times prevents you from doing other productive things (like work, homework, having a life, etc).....
1. In the earlier years it was called burgundy berry... Crimson pearl was later IIRC... Look on the drivers side firewall to see your color code (on the plate)..... If it says AL0 that means its crimson pearl, otherwise its burgundy berry...
2. Like they said, the dealer should take care of the amps.....
There is a step by step somehwere on the door panels... Basically you slide back the armrest, remove 3 screws, pry off the plastic surround for the seat controls, and right above the grab handle is the final one... Unscrew, and then there are clips going all around. Best to pry them off individually.....
