ajheddings »
https://forums.nicoclub.com/ajheddings-u39323.html
Sat Apr 08, 2006 8:00 am
Yes...I searched the forum for clues on how to fix this. No luck, although I did read that there are two master fuse boxes under the hood that may be responsible.
Having trouble with 96 Q45 (don't laugh, but I just bought it yesterday)...sometimes on startup, the entire instrument cluster, air conditioner, cruise control, rear defrost, power windows, sunroof and dimmer switch will all be without power simultaneously...then all at once, they come back on without warning, sometimes a couple of minutes later. It seems that they are all under the same circuit and there is a loose wire or fuse, a short or some sort of ground. Has anyone dealt with this before? Does someone with knowledge of the electical system know what the culprit could be? This happens about 25% of the time on start-up. Other times power goes out on the road without warning...then comes back on minutes later (perhaps after hitting the right bump in the road). I can live with this problem, but these things only get worse...right? My thought is that the major clue as to what is wrong has to do with the fact that windows/roof controls go out simultaneously with the instrument cluster and the controls in immediate proximity to it. This 'clue' must lead a skilled auto electrician with an electrical diagram right to the problem, right? I'd really like to avoid paying a grease monkey $600 in labor to tear apart my dash and NOT fix the problem. Does anyone have a recommendation on who to take this to for troubleshooting/repair? I'm going to check for a loose master fuse today and see if that could be the problem. Even with this gremlin situation, this car was a STEAL at $3700 with 110k and pristine condition inside and out. Thanks,AJ
