zero-six-s13 »
https://forums.nicoclub.com/zero-six-s13-u68134.html
Thu Jun 14, 2007 9:07 am
Thanks for the response and the welcome. So, I will just pick that safvc and not use the the V-teck feature. (I don't know what water thing you're talking about)
I'm hoping to build this as reliable as possible because it is my daily driveer. Hoping to boost around 7-10 psi...
Sitting in my garage cabinet is as follows:T3/T4-50 trimHKS Blow off valveTial 38mm Waste GateFMIC (small)370 cc Injectors255lph fuel pump
To come will be as follows:Oil LinesSAFC - If deal above falls through Greddy UltimateKoyo Radiator + SS OverflowThreadstone IC pipes + Silicone cuplers / T-ClampsThreadstone Top Mount Manifold + T3 Down Pipe + Dump PipeMSD ignitionGaugesssssss
This should complete the gathering of Turbo parts
And alot of other suspension and brake stuffMy wallet is low =( but for some reason, i would rather spend money like this then buy a boosted car from the factory..
Modified by zero-six-s13 at 1:47 PM 6/14/2007
Modified by zero-six-s13 at 1:49 PM 6/14/2007
