Welcome to NICO. It sounds like you've got yourself a well maintained Q with a known service history. You didn't mention larger than stock tires being installed so for the rubbing issue check the wheel well liners on both fronts. If one or 2 of the fasteners are missing they can sag and rub on the tire.TellarHK wrote:....When driving in reverse, with the wheels cranked all the way to the left, there's the distinct and clear sound of something grinding or rubbing at the front driver's wheel........There's a smell of burnt rubber as well, so I'm wondering if the tires that were put on it just before the car was shipped to me might have been installed incorrectly?.....
I think all the boots are good, though I will be checking the components under the driver's side wheelwell for obvious reasons. And yeah, it's a pretty base model of Q. I'm figuring that's probably a good thing, as maintenance would have been more of a nightmare. It looks like what my folks had to replace before was the Body Control Unit, BTW. I would have aimed for a used one, myself.ppastos wrote:So that problem is resolved (with the key less entry) all you have to do is check the battery in the remote and replace if necessary.
And you mean it has no active suspension or Rear steering AKA HICAS, Its also rare to see a 1994 Q45 without TCS.
Hope its just a dead battery and not the controller. but if it is the controller then I have one for sale.
I would also check all the rubber components on the car, Ball joints steering rack dust boots just to name a few.
Not to get off topic, but hypothetically if one were to damage the wheel well liner and be missing a significant portion of the passenger side one, where would said person be able to procure a replacement?goody94q45 wrote:
Where can I buy this elusive 1904 model Q45?maxnix wrote:Lots of 1904-1996 did not have TCS, thankfully.
Hope they shipped you the records also!
Welcome to NICO!
Do lots of reading here, starting with the FSM
http://www.nicoclub.com/FSM/Q45/
Don't know if you seen what Mike said but it does happen out of nowhere. Towing is costly...Like most mechanical parts on this car, its pretty self explanatory if you just look at it.goody94q45 wrote:For the burning rubber smell I'd take a look at the 3 idler pulleys which are the tensioners for the belts. One of them could be frozen (common problem) after sitting for so long and could be close to taking out a belt.
I don't have the underside totally committed to memory, but could it be a hose of some sort touching a hot spot?TellarHK wrote:I did see that, but the burning rubber smell is definitely only caused by the driver's front wheel when it's cranked full left in reverse. I haven't had that issue in the past few days since discovering it, and avoiding that sort of turn until I can get it someplace where they can pop the wheel off and look. There are no problems under the hood. The car also only sat for a week and two days on a truck, and it had been driven regularly before that.
So it's good to know about the belts in the future, but I'm positive those aren't a problem now.
