New Q on the Block
Eskimo91q45
Car: 91 Q45
91 Grand Marquis
Hey guys got my Q bout 6 months ago recently started working on it just redid all the breaks rotors and calipers but the Power steering pump is out if any one has one by chance. but besides that the car is awesome i love the look and feel of it and just joined this site for support as i go though. but thanks in advanced guys glad to be apart of the infiniti club.
GSUjinih
Car: 1993 240SX Coupe
1993 240SX Vert
1994 Q45
Where are you located at? Saw an inexpensive one with warranty on Ebay: http://www.ebay.com/itm/90-91-92-93-94- ... 320wt_1396
Also you can have your pump rebuild for about $100:
http://www.rockauto.com/catalog/x,carco ... ttype,7380
OwnerCS
The PS pump is a simple unit.. I've had good luck with a Felpro unit from AdvanceAuto. I think I got it on sale for around $100 at the time. They have some good sales on the Web site.
OwnerCS
OK - here's the video. It takes a minute or two to load so be patient.
http://fliiby.com/file/473220/xos1f93xr0.html
Eskimo91q45
Car: 91 Q45
91 Grand Marquis
Awesome... im located in Florida i forgot to look on ebay i will deffently need one as it makes a horrible noise and at frist start up it doesnt wanna steer for a few seconds. i was wondering is this common on the Qs? and thanks for the links..
Q451990
:welcome: to NICO!
P/S pump failure is extremely unusual for the early Q. I'm assuming the fluid level is OK - it's growl if it's low...
Heath
Eskimo91q45
Car: 91 Q45
91 Grand Marquis
I see yea deff growls its real loud maybe it's got a leak out somewhere thanks I bet the pump is going out cuz of constant Low fluid I'll figure it out it kinda looks likes the resavor is leaking thanks guys I already love this site
GSUjinih
1993 240SX Vert
1994 Q45
My power steering pump is very noisy. I think somebody ran it low at one time. I am going to flush it out and try out some different power steering fluids. I remember GM pumps crapped out very easily on factory Dexron fluid, but I tried STP Honda universal and it did not fail even after some serious autocrossing.
Skibane
Car: 2000 Q45 AE 110K
Mobil 1 Synthetic Automatic Transmission Fluid works well as a replacement PS fluid. It's not particularly expensive, and readily available.
GSUjinih
1993 240SX Vert
1994 Q45
Sounds like I will give that a try. Thanks for the tip!
Eskimo91q45
Car: 91 Q45
91 Grand Marquis
anther couple questions... but i was reading the whole 90-93 timing chain guides prob...so i was wondering if these parts are found at a part store or if i have to call a dealer but i live in central florida and i just redid my entire brake system now i wanna get this job done b4 i end up buying another Engine any tips or tricks about getting these parts would be awesome i read most of the write ups on here about how to do it now i just need the parts
GSUjinih
1993 240SX Vert
1994 Q45
Not sure how expensive factory parts are exactly and how critical using factory parts are for this job, but here is a good place for aftermarket parts:
http://www.rockauto.com/catalog/x,carco ... ame,Engine
Eskimo91q45
Car: 91 Q45
91 Grand Marquis
i just bought that P/S pump from the ebay link above after that im gonna be working on getting it not to run so rough so where should i start? i just tolk it out on the road after a long sitting and ran rough the guy who owned it before me addmited he put reg gas in it alot so is that anythng to do with it. seems like its missing but no engine codes...
goody90q45
Car: 1992 Infiniti Q45 (sold)
Eskimo91q45 wrote:i just bought that P/S pump from the ebay link above after that im gonna be working on getting it not to run so rough so where should i start? ...
I'd start by ohm testing the fuel injectors (and KS while you're there).
Next, clean and tighten the pins on the MAF sensor connector, CAS connector, and EGR soleniod connectors. The pins should look like the middle one in the pic. These connectors aren't waterproof and are subject to corrosion, especially if you've ever had a radiator leak. Also apply a light coating of dielectric grease to these connectors.
Finally, add a bottle of Redline S-1 fuel injection system cleaner to a 1/2 tank of fuel and drive for an hour or two.
Eskimo91q45
Car: 91 Q45
91 Grand Marquis
Sweet i will sounds like it just needs some TLC..im gonna bleed my P/S pump and see if that fixs the ride issue a lil and idk if this is normal for this car or not but when u go over any kinda bumps or anything thing the rear end just bounces up and down seems like a lil more then it should just wondering if this was a sign of bad shocks or not thanks goody im gonna go out there and see what i can find
