It washes that many contaniments into the oil? If so I'd better get on it but I'd hoped to wait until right after my next can of BG-44K, in about 400 miles.yodawill2000 wrote:You should change the oil after using the BG44k !
Thats how strong that stuff is !!!
Isn't NICO an amazing site? Great bunch of folks and an unbelievable archive of past threads.Americain wrote:You would not believe how much knowledge I've picked up while browsing this site, thanks everyone.
1.) By "lubed" I hope you are referring to the caliper pins.Americain wrote:So far it's going pretty well. Here's what's been done...
1. Brake calipers have been dismantled and lubed. Just for good measure a new master brake cylinder was installed. 2. Two fuel injectors have been replaced. The car runs pretty well as you might expect.3. I recently purchased an upper control arm from Scottsdale Infiniti and when it arrives I will have it installed and the front end aligned. 4. I ran a can of BG-44K through it and I can see the difference. I'll do it again after a couple tankfulls. 5. I cleaned out the throttle body with carb cleaner and have yet to test drive the car. Hopefully it will show even more improvement.
Not exactly true as Rex had an early OEM dealer installed Sony CD player for the Clarion head unit.Jesda wrote:Only CD changer you can add would use an FM modulator or tape adapter, and it would have a separate control unit.
How was it connected to the head unit? How do you control the changer?maxnix wrote:Not exactly true as Rex had an early OEM dealer installed Sony CD player for the Clarion head unit.
1. Actually it was the rear caliper slides which had frozen.maxnix wrote:1.) By "lubed" I hope you are referring to the caliper pins.
2.) "Pretty well"
3.) Best replaced in pairs. Now your other arem is looser and will fall out of alignment sooner. How about the tension rod bushings? Tie rod end links?
4.) Why a new owner changes all fluids and filters presuming theyhave expired without verifiable evidence to the contrary.
5.) Read the under plenum threads. This will produce the most gain in reliability and performance.
Welcome to NICO You've made a great start.
Modified by maxnix at 10:08 PM 10/26/2007
The Infiniti Master Tech at the dealership advised against it. As a Q owner himself I felt it was a good idea to listen to him. He also said that it was a good idea to start the car and give it 15-20 seconds so that the oil pressure can tighten the timing chain. Starting the car and stomping on the gas is to be avoided. My Q has been very well maintained through an Infiniti dealership so I'm fairly confident that I can take his advice.mxr662 wrote:The chain guides get brittle with age. I would recommend changing them. The ones in my 1990 were perfect but brittle.
Welcome to Nico
This looks like a new owner welcoming thread - so I will join in. Seems like you got a great deal. I am amazed at how much research you did before buying the car - great job. I wish you good luck with your car and many years of happy motoring!goody94q45 wrote:Looks like you got a great deal for $1800 for a dealer maintained Q. Congrats. IMHO if you're not going to change the guides you ought to at least remove the covers and check them for peace of mind. Your call.
I'm curious what the build date is on your 93Q. You'll find it on a label on the driver front door sill. If it's unreadable I think it's also on the driver side firewall. For the record, I've got a 94Q, with metal backed chain guides, with a build date of 2/93.
CD player- For laughs have you removed the trunk trim panel covering the antenna motor to look for an unused electrical connector? I don't think the 93Q had the side mounted CD player but it only takes a few minutes to check.
Jesda's right about going the FM modulator route. The install is pretty easy since it ties into the antenna cable. Check the Infiniti Parts forum, there's one for sale cheap.
For future reference, would you tell us which dealership this is, so other Q45 G50 owners know they can find a competent Infiniti Master Tech in Columbus, Ohio?Americain wrote:The Infiniti Master Tech at the dealership advised against it. As a Q owner himself I felt it was a good idea to listen to him.
While it may not have been as worn, it will still not be as tight as new.Americain wrote:3. The suspension guy who shook down the Q felt that all those other areas were solid. I'll deal with them as they come up.
Depends how lucky you feel. Ask him if he personally will guarantee parts and labor for your car if the timing chain guides fail? That should give you a really good clue.Americain wrote:The Infiniti Master Tech at the dealership advised against it. As a Q owner himself I felt it was a good idea to listen to him. He also said that it was a good idea to start the car and give it 15-20 seconds so that the oil pressure can tighten the timing chain. Starting the car and stomping on the gas is to be avoided. My Q has been very well maintained through an Infiniti dealership so I'm fairly confident that I can take his advice.
Aa illustrated above, best thing not to do with original early chain guides is start the car. So sitting back is a great option until you remove the front covers for an inspection and timing guide change.Americain wrote: Of course, there's no real sitting back, right?
This is the stupidest thing I've heard in a bit. A mechanic is going to give a full warranty on an used engine with likely over 100K?maxnix wrote:
Did your "tech" give you that written guarantee for parts and labor?
